GM Crate short block info(Joe Lucia) - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    Does anyone know the details of this crate short block? Was told it is an original GM LT-1 short block.
    • 43297
    Re: GM Crate short block info(Joe Lucia)
    [ATTACH=CONFIG]100810[/ATTACH]
    [ATTACH=CONFIG]100811[/ATTACH]
    Dennis------
    It could be. Or, it could be an L-46 short block. I cannot discern the last 4 digits of the part number stenciled on the crate. That's critical to ID.
    • Dennis D.
      • March 1, 2000
      • 1071
      Dennis------
      Thanks Joe. I thought possibly L46 as well. Im told solid cam though.
      Isn't that number on the block the same one that's on the crate?
      . Would there be a timing cover and oil pan?
        • 43297
        Dennis------
        No, the number on the crate is the part number for the engine assembly. That's what's needed to identify the assembly. The number on the block is the casting number for the block. There's no way it would be on the crate even if the engine within was a bare block. Both numbers begin with "397" and, possibly, "3970". But, the rest of the number is different.
        Short blocks were usually not supplied with timing cover or oil pan. I highly doubt that this one includes those parts.
        • Keith B.
          • September 15, 2014
          • 1604
          since its a short block wouldn't it have a assembly stamp with suffix code?
          • Patrick B.
            • August 31, 1985
            • 2018
            I think a short block would have a CE number. If it comes with lifters you can check whether they are solid or hydraulic.
            • Dennis D.
              • March 1, 2000
              • 1071
              Couple more pics. Dont think I see cam lobes.
                • 43297
                Keith------
                No suffix code. Suffix codes denote a complete engine configuration. This short block could have been built into at least 6 engine configurations (Corvette and Camaro).
                  • 43297
                  [ATTACH=CONFIG]100812[/ATTACH][ATTACH=CONFIG]100813[/ATTACH]
                  Dennis------
                  I don't see cam lobes, either. Short blocks were supplied with an installed camshaft. So, it's been removed in the case of this short block.
                  If the part number on the crate is 3970653, which is likely, then it's an L-46. Of course, without the cam it could now be configured into either and L-46 or LT-1 depending upon which cam was installed.
                  The 1970 LT-1 short block was GM #3966921. The number on the crate is definitely not that number.
                  • Patrick B.
                    • August 31, 1985
                    • 2018
                    Pink rods look like LT-1.
                      • 43297
                      Patrick------
                      Both L-46 and LT-1 used the same connecting rods. L-82, too.
                      • Dennis D.
                        • March 1, 2000
                        • 1071
                        Have better pic of crate number. If this is a L46, am I correct in the cam is the only difference in the short block.
                        • Lawrence M.
                          • February 1, 1995
                          • 404
                          Yes the only difference is the cam. Both LT-1 and L46 used the same forged crank, pink rods and 11-1 pistons .
                          Larry
                          2002 Z51 Convertible
                          1969 L46 Convertible
                            • 43297
                            [ATTACH=CONFIG]100819[/ATTACH]
                            Dennis------
                            Yes, the number cinches it and, yes, the only difference between L-46 and LT-1 partial engines ("short blocks") is the camshaft. One interesting side-note: L-46 was Corvette only. LT-1 was both Corvette and Camaro.
                            • Dennis D.
                              • March 1, 2000
                              • 1071
                              Thanks all for confirming
                              L46 I know. Had one for 45 years. LT-1 is somewhat different, obviously not in the short block.
