What do you think of this Corvette Central exhaust that arrived? (photos) - NCRS Discussion Boards
  • John S.
    • June 15, 2015
    • 506
    I tried to take the photo as level as possible (taken from the RH side) but I think you can clearly see that the left hand pipe sits a bit lower as it approaches the cross member. Neither of my pipes are flattened but perhaps with the weight and suspension travel of a BB, it might make sense as to why your LH pipe is flattened.
    i would certainly call CC to verify but this might give you some insight if they say it is correct, good luck !!
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • Mark E.
      • April 1, 1993
      • 4597
      Re: What do you think of this Corvette Central exhaust that arrived? (photos)
      Thank you Owen and John! Very helpful. This builds a theory why CC crushed the left pipe but not the right.
      The CC exhaust expert is supposed to call soon; I'll share what I learn.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Erich M.
        • November 1, 1985
        • 65
        Mark,
        For what it's worth, attached are photos of my original 72 LT1 exhaust. Both sides are crushed flat and crimped.
        Erich Meyer
        Original Owner 72 LT1 - Bowtie & Top Flight
        • Mark E.
          • April 1, 1993
          • 4597
          I (finally) installed the CC exhaust system this weekend. I'm happy to report it went together great without any issues or modifications: Tips are centered, pipes go through the cross-member holes without touching, and there's good clearance with the floor.
          After the old exhaust was removed, installation took two hours at a leisurely pace.
          A true bolt-on experience.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Ed S.
            • August 6, 2014
            • 1377
            I told you! Glad to hear all went well for you.
            Ed
            • Tim G.
              • March 1, 1990
              • 1386
              That's good news, Mark.
              • John S.
                • June 15, 2015
                • 506
                • Mark E.
                  • April 1, 1993
                  • 4597
                  Originally posted by John Sigmund (61302)
                  Mark, glad to hear it went well, now the burning question is how does it sound ??
                  I think the 2 1/2” CC system on my L82 sounds perfect. Sounds great at idle, not annoyingly loud on the highway and I can always drown out the radio if I put my foot in it.
                  I'll let you know when the car is put back together.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Mark E.
                    • April 1, 1993
                    • 4597
                    #24
                    Should the angle/position of the left muffler mirror that of the right?
                    I just noticed the right muffler is more steeply angled and drops down more than the left muffler. The pipes are aligned the same side to side; each pipe also has the same clearance with the rear carrier. And each exhaust tip is centered in its valence opening.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Larry M.
                      • December 1, 1986
                      • 541
                      #25
                      Mark,
                      What are you using to raise/support the car?
                      Larry
                        • 11659
                        #26
                        If you paint those mufflers black like original, you'll never notice any difference in angle. It's subtle in your photo, and I'm not sure I would mess with it.
                        • Richard G.
                          • July 31, 1984
                          • 1715
                          #27
                          Without and adjustment (because of the welds) I would call this a keeper.
                          Way better luck than I had with my internet exhaust.
                          Enjoy.
                          Rick
                          • Mark E.
                            • April 1, 1993
                            • 4597
                            #28
                            Originally posted by Larry Maher (10731)
                            Mark,
                            Larry
                            QuickJack. It worked well during chassis restoration and exhaust installation. Great for wheel well detailing and brakes too.
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                            • Mark E.
                              • April 1, 1993
                              • 4597
                              #29
                              Is this level of alignment within TFP?
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
                                • 11659
                                #30
                                It's not drastically different than my 2008's exhaust, that's for sure.
                                And, as hard as I have to look to see it I'd never notice it judging, especially if blackened.
