L71 Correct Timing Cover - NCRS Discussion Boards
  • Gary F.
    • April 1, 1983
    • 36
    Does anyone have a source for a correct L71 timing chain cover for my 67 corvette?
    • 43247
    Re: L71 Correct Timing Cover
    Gary------
    What you need is a GM #3885054. This is a non-dowel pin type cover with timing tab for an 8" balancer. Unfortunately, it was discontinued in May, 1969 and replaced by GM #3935444 which is the dowel pin type cover which also SERVICES non-dowel pin applications. Given that the 3885054 was discontinued 51 years ago, finding an NOS example will be a challenge, to say the least. If you did find one, I'll bet it would be selling for a king's ransom. Used examples, of one condition or another, may be out there but I bet they command high prices, too.
    There is a reproduction of the 3885054 available. From what I've seen of it, it looks pretty good. I expect that most of the Corvette parts vendors carry it.
    • Daniel Y.
      • September 30, 2002
      • 185
      Gary,
      buy the repro and fill in the hole on the bottom
      Dan Young
      65, 67 Duntov x2
      66 bowtie x 2
      71 LT1 TF
      90 ZR1 McCelland
      03 Anniverary
      06 Z06
