1960 Radiator question - NCRS Discussion Boards
  • Joe P.
    • October 4, 2007
    • 209
    I installing my rad and preparing to flush the system, including removing the two plugs on the block and have a question regarding air flow around the radiator particularly along the bottom of the radiator.
    Is the gap in the picture normal or am i missing anything to deflect the air through the radiator, as opposed to below it..
  • Frank D.
    • December 26, 2007
    • 2703
    Re: 1960 Radiator question
    The triangular corner seal looks correct and if you have the bottom seal then I'd say its correct. However the shrouds are a bit "wanting" around the sides and top. For driven cars many add closed cell foam pipe insulation on the top and down each side. Strictly your call but I did on my '61. Its effective and easily removed if desired.
    • Joe P.
      • October 4, 2007
      • 209
      Thanks, i will have to try that.. was wondering if you did anything to block the air flow between the bottom of the rad and the rad support?
      • Frank D.
        • December 26, 2007
        • 2703
        My 61 had a long rubber horizontal seal that ran along the bottom of the radiator in between the two triangular corner pieces - I didn't add anything else.
