What is supposed to go here? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1391
    Guys,
    I'm looking at the front side of the front wheelwell of my 69 L-46 4spd non-AC car and there is an area that clearly had something mounted there that has been removed during the restoration (see attached pic) but I don't know what was there. This is present in both left and right wheelwells. Can somebody tell me what is supposed to be mounted there?
    Mike
  • Owen L.
    • September 30, 1991
    • 871
    Re: What is supposed to go here?
    If I've got my orientation right, looks like the nose header bar attaches there.
    • John S.
      • June 15, 2015
      • 505
      That is correct, on each side of the header bar there is a triangular bracket from the bar to the inner fender. Note the fastener that goes from the bracket to the underside of the header bar.
      On the other side there is a rectangular bracket and the two screws that fasten it to the inner fender. Not the greatest photos, hope they help. Both photos are from the LH or drivers side, RH side similar, the triangular brackets are L and R handed.
      1973 L82 M21 4 Speed, very original and well documented driver/survivor
      NW Chapter Member, 2016 Bend Regional Top Flight
      73/74 TIM&JG 3rd Edition Revision Team Member
      • Michael L.
        • December 15, 2006
        • 1391
        Thanks guys that's definitely it. I found the brackets on my shelf and will re-install them.
        Mike
