C2 disc brake dust shields - NCRS Discussion Boards
  • David M.
    • December 11, 2011
    • 48
  • Stephen L.
    • May 31, 1984
    • 3161
    Re: C2 disc brake dust shields
    MEK or paint stripper may work. Also lots of laquer thinner might do the trick
    • David M.
      • December 11, 2011
      • 48
      Stephen,
      thanks for the info. Will try both and hopefully I can restore without having to paint.
      • Joe R.
        • July 31, 1976
        • 4551
        Bair's sells new ones. They won't have the part number but are new and plated. Only 30 bucks each.
        JR
        • David M.
          • December 11, 2011
          • 48
          Stephen,
          I used paint stripper and the shields turned out like new. Can even see the part number. Thanks for the tip.
          • Stephen L.
            • May 31, 1984
            • 3161
            Originally posted by David McMenamin (54179)
            Stephen,
            Glad I could be of help....
            • David M.
              • December 11, 2011
              • 48
              Stephen,
              Looks like when the car was new they added textured undercoating to the floor boards. I am not going to try and remove that but instead clean and touch up. I plan on using a flat black. What are your thoughts of a water based or oil based flat black?
                • 43247
                Stephen,
                David------
                I would use only an oil-based paint.
                • Stephen L.
                  • May 31, 1984
                  • 3161
                  David
                  I think you'll find that things won't match if you just touch up..... If using a rattle can I'd use Krylon flat black. If you are going to spray cover the car completely with a sheet or blanket. It's eye opening where over spray can migrate to........
                  • David M.
                    • December 11, 2011
                    • 48
                    Thanks Joe. Why oil based?
                      • 43247
                      David------
                      I consider it much more durable and it's the only type of paint ever originally used on a C2 or C3 Corvette.
                      • David M.
                        • December 11, 2011
                        • 48
                        Thanks Joe.
                        • David M.
                          • December 11, 2011
                          • 48
                          Thanks Stephen. Agree with the cover to protect against over spray.
