Fuel Tank Sock(On the pickup in the tank) C2 Corvette - NCRS Discussion Boards
  • Larry E.
    • 1677
    If the above sock is collapsed;kinked or just needs to be taken off or repositioned can this
    be done w/o taking the tank down? I understand that the pickup and sock can be seen from
    the fuel fill neck. Please advise. Thanks in advance>Larry P.S. The sock is just pushed on the
    pickup tube; correct?
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1677
    Re: Fuel Tank Sock(On the pickup in the tank) C2 Corvette
    Added Question>If sock for some reason is clogged could shooting some compressed air from the fuel pump
    area back to the tank help?? Thanks again>Larry
    Larry
    • Gary J.
      • April 1, 1980
      • 1242
      Try to siphon as much gas out as possible. You could jack the car up to one side to try and get as much out as you can before drawing the tank.
      • Larry E.
        • 1677
        Anybody else to answer my particular questions? Car is at a vendor now and needs to be moved to another place to work on.
        Just want a simple way of getting it to run and move. Anybody try that compressed air idea?? Larry
        Larry
        • Larry E.
          • 1677
          Thanks for the response but you guys ARE NOT READING MY QUESTIONS. THE CAR CAN NOT BE WORKED ON WHERE IT IS SITTING
          NOW FOR VARIOUS REASONS. WE GOT TO MOVE IT TO ANOTHER BUILDING. In baseball terms you guys are wonderful 3rd base
          coaches; I more concerned about getting to 1st base 1st. Anybody?? Thanks to all>>Larry
          Larry
          • Patrick B.
            • August 31, 1985
            • 1995
            Someone with a skinny arm may be able to reach into the fuel opening and just pull the sock off. I've seen it done with a 68 convertible. A coupe would be more difficult
            • Frank D.
              • December 27, 2007
              • 2703
              OK - the fact you don't like the answers doesn't make them irrelevant. How far are you going ?
              That sock (if that's really the problem) isn't going to fix itself,; if its damaged or deteriorated, you are setting yourself up to get 1/2 way to your destination and have the problem reoccur (only worse) and then you've got add'l problems... Based on your other thread, it doesn't appear you're 100% certain that the sock is even the problem...
              i will tell you this - my Dad traded in a 1929 Dodge decades ago and we needed to move it a mile or so to our shop....the gas tank was completely shot. We rigged up a 2 gallon fuel container secured to the running board with a rubber hose to the fuel pump to get the car where it needed to go.
              Dangerous, and I'm not recommending it, but its been done before...
              • John F.
                • March 23, 2008
                • 2409
                A flatbed tow truck will work just fine to the next location.
                • Bill M.
                  • 1327
                  Reach in with a coat hanger and rip the sock off or reach in with a sharpened piece of 1/8 theaded rod and poke a few holes in the sock. Or you could flat tow it with another car just communicate with cell phones.
                  • Roy S.
                    Past National Judging Chairman
                    • July 31, 1979
                    • 1025
                    I have blown the sock off of a tank with compressed air. It was a long time ago and it was a 75 convertible, but it was plugged enough it would not allow full flow to the pump, we blew the sock off. added an inline filter under the tank and drove that car a lot of miles.
                    • Perry M.
                      • January 1, 1977
                      • 325
                      All good suggestions. Pick one and do it and stop yelling, GEEZ.
                        • 43221
                        Larry-------
                        The strainer is a light press fit in the pick-up tube and is rather easily removed and installed. It was GM #5651702 but it's discontinued. It's available in the aftermarket, though.
                        • Mike E.
                          • February 28, 1975
                          • 5138
                          • Bill M.
                            • 1327
                            If I cant find my Bic I use my BBQ grill igniter
                            • Larry E.
                              • 1677
                              Mission Accomplished>The culprit was the fuel pump. Who would think a NOS #6415616 would not work? We put another one
                              on that we knew worked and fired the engine(L75) up. Want to thank everyone who responded. Got to know a lot more about
                              the "sock" in the tank; may have to cross that bridge in future. Hope to get this buggy judged next year. Thanks again>Larry
                              Larry
