1967 Holley 3811 manifold gasket/shim - NCRS Discussion Boards
  • Owen L.
    • September 30, 1991
    • 869
    My '67 427/390 has a replacement (repro) Holley that I got about 10 years ago. It came with a steel 4-hole shim that I used between the carb and the manifold gasket, which is a 4-hole gasket with the crossover slot.
    Is there any kind of gasket used between the flat steel and the carb? When I took my carb off to check idle slot and secondary presetting, there was evidence of fuel seeping between them. I assume if fuel is seeping, then air is also traveling in the opposite direction.
    Thanks for any info on my question or how to install the carb to eliminate the seeping.
  • Vernon S.
    • November 1, 1997
    • 32
    • Stephen L.
      • May 31, 1984
      • 3158
      Re: 1967 Holley 3811 manifold gasket/shim
      There is a gasket on the manifold with a metal baffle on top and then the carb mounted on that. 67 427/390 w/3811 Holley carb.
      Check your AIM
      • Owen L.
        • 869
        Thank you Skip and Stephen.
        So it sounds like my parts and installation are correct:
          • 43222
          [ATTACH=CONFIG]100459[/ATTACH]
          Owen------
          Yes, the shield is there to prevent direct exhaust heat from the "heat slot" from directly contacting the carburetor. If this were to occur, the carburetor would be destroyed in short order.
          The best plan is to plug the holes on either end of the "heat slot" thereby eliminating its functionality. Even with the shield the "heat slot" still causes a lot of carburetor problems and is best eliminated. After elimination, the shield would not actually be necessary but it won't harm anything to leave it installed.
          GM eliminated the "heat slot" after 1969. Good riddance.
          • Owen L.
            • 869
            Joe,
            What is the procedure to plug the holes? Does the manifold need to be pulled to do it?
              • 43222
              Joe,
              Owen------
              The holes can be plugged in either of two ways. First, drive plugs (cup shaped plugs like small freeze plugs) can be installed. These are simply driven into the holes. There is no need to remove the manifold. I do not recall the size but simply measure the diameter of the holes and use the appropriate size.
              Another method is to drill and tap the holes for internal hex drive NPT plugs. If the manifold is on the engine one needs to exercise care to catch and remove the metal chips. This is not too difficult. However, keep in mind that any chips that are missed will not enter the engine, only the exhaust system. They should not do any real harm here.
              • Owen L.
                • 869
                Thank you Joe. Both methods sound quite doable and it's good to hear the manifold can stay on the engine. Perhaps the next time I need to pull the carb I'll tackle it.
                • Tom D.
                  • September 30, 1981
                  • 2134
                  We are dealing with issues on a '67 this week. Plugging of the "cold enrichment" feature (if I have the words right).
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                  • Owen L.
                    • 869
                    is the purpose of blocking the cold enrichment passage to help alleviate heat soak of the Holley?
                      • 43222
                      Owen------
                      That's one of the purposes. But, as far as I'm concerned, the main purpose is to prevent deterioration and distortion of the carburetor. Even with the shield, a lot of heat is transferred to the carburetor.
                      • Tom D.
                        • 2134
                        I'm doing it (with plugs and the under-carb shield) to improve performance when the coolant gets to 200 degrees F.
                        Michigan Chapter
                        Tom Dingman
