Speedo/Tach light button connectors - NCRS Discussion Boards
    • 11679
  • Dick W.
    • 10483
    Re: Speedo/Tach light button connectors
    If you are talking about what I am thinking of, they are soldered on the wire. I have taken a soldering iron and removed the old wire, stripped the wire and tinned it and put it back on the wire. A little tedious but it works
    Dick Whittington
      • 6950
      Pat if you have a Old dash harness or know of someone that has one you can salvage a socket. Those sockets with a single wire cover quite a few years.
        • 11679
        The problem is that they are crimped on. The original crimp is quite heavy, and next to impossible to open up.
        We were successful on 2 of them, but not the 3rd.
        I could graft on another socket, but would rather avoid splicing.
        I have never in my life successfully soldered anything, despite multiple attempts.
        • Floyd B.
          • November 1, 2002
          • 1050
          Here ya go. Used a couple just last weekend for the exact same repairs to my '69 speedo lights.
          As you have already noted, you will need to have the proper crimp tool:
          You can find good crimp tools on ebay for less than 1/2 this price but if you want one-stop shopping...
          "Drive it like you stole it"
            • 11679
            Floyd,
            I saw those out there, but they are different than the originals. The originals did not use tabs to fold over and crimp.
            Are these then small enough diameter to make it through the hole in the socket?
            PH
            • Floyd B.
              • November 1, 2002
              • 1050
              Pat,
              I had no problem with the finished crimp fitting into the socket. Here are some pics:
              • Floyd B.
                • November 1, 2002
                • 1050
                They also sell these replacement sockets with pigtails. A previous owner replaced one of my lamps with these. They aren't configured exactly the same as originals but they fit just fine and I bought a few to keep around just in case... They fit just fine into the 5/8" lamp holes on the speedo and tach.
                  • 11679
                  I've seen those, and Lectric Limited sells one that looks more correct. However, I'd like to avoid crimping on an extra piece if able.
                  • Floyd B.
                    • November 1, 2002
                    • 1050
                    That's why I went with crimping a new button onto the wire and saving the original socket. It was an easy fix and looks and works fine. Good luck.
                    • Dick W.
                      • 10483
                      Patrick, the secret to soldering is to tin both pieces. Heat the wire just enough to where the solder will melt from the temp of the wire, not the iron. Same for the other piece. Then place the parts together and heat again until the solder flows on both pieces. Just make sure you use rosin core solder on wiring. Acid core will cause many more problems that what you are trying to cure.
                      Dick Whittington
                      • Peter M.
                        • May 30, 2013
                        • 359
                        Patrick,
                          • 11679
                          Yes, that looks like the originals.
                          • Peter M.
                            • May 30, 2013
                            • 359
                            Patrick,
                            How many do you need?
