Small Block Coolant Drain Plug - NCRS Discussion Boards
  • Larry M.
    • January 1, 2002
    • 538
    There is a post which says this is part#3889330 (Joe Lucia). Then there is this link:
    https://www.forums.ncrs.org/showthre...hlight=3889330
    This is a discussion about plugging the exhaust manifold on non air cars for export which says the thread would be straight pipe thread and not NPT.
    Should the coolant drain plug on C2 small blocks be straight or NPT? Is the 3889330 straight or NPT?
    • 43273
    Re: Small Block Coolant Drain Plug
    Larry------
    All Corvette small blocks I am aware of used a petcock for radiator coolant drain. These petcocks were all NPT thread.
    If you are referring to the block coolant drains, those were also NPT thread. The plug was external hex head steel.
    • Larry M.
      • January 1, 2002
      • 538
      Joe, do you know the part number for the block plug? Is it the 3889330 or some other number? Sorry I didn't make it clear which plug.
        • 43273
        Larry------
        3889330 is the part number. However, it's long-since GM discontinued. No matter, though, identical plugs are easy to find, either in a good hardware store or from a source like McMaster-Carr. Nothing special about these plugs, at all.
          • 15631
          Larry------
          Joe
          For original 1968 to 1972:
          We have observed copper/brass radiators with a bottom drain that have a 90* fitting (a male end is soldered into the bottom of the passenger side header tank) and the other end of that 90* fitting has a brass plug with a hex head. We also see copper/brass radiator with a side drain that use a petcock. So far we have been unable to establish a pattern to either style drain.
          My early 1970 had the 90* elbow with brass hex head plug.
