Best Quality Throw Out Bearing, Clutch & Pressure Plate for M21 mated to L36? - NCRS Discussion Boards
  • David J.
    Infrequent User
    • September 30, 1990
    • 28
    The throw-out bearing in my M21 needs replacing. Any recommendations for a high quality throw out bearing, clutch and pressure plate would be appreciated. I've searched the archives, but haven't come up with much. Thanks
  • Mark E.
    • April 1, 1993
    • 4603
    https://www.corvetteforum.com/forums...l-range-2.html
    It doesn't discuss throw-out bearings. I'm looking forward to what the experts on this forum recommend.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Michael H.
      • December 1, 1987
      • 731
      Re: Best Quality Throw Out Bearing, Clutch & Pressure Plate for M21 mated to L36?
      I'm not an expert but take a look at LUK they sell a complete package.
      Mike
        • 43258
        David------
        If you want as close to stock performance and fitment, I recommend going with a LUK clutch. In your case, this would be a LUK #04021. This is a kit which contains pressure plate, friction disc, and release bearing. However, if it were me, I would obtain and use release bearing GM #19245400 aka ACDelco CT24KVAL. This is an OEM quality release bearing. You may find that it's made in China but the fact remains that this is an OEM quality release bearing, not aftermarket quality.
          • 6950
          Don’t use the sindered iron pilot bearing, that’s what I have seen in the Luk kits. National makes a Oilite bearing. Hope I spelled that right.
          • Dan D.
            • November 5, 2008
            • 1323
            I second what Ed said about the pilot bushing. If it is sindered iron it will wear out. You can tell if it is iron as it will be magnetic and will suck right up to a magnet.
            -Dan-
            • Thomas N.
              • July 31, 2002
              • 402
              How about an OEM GM Clutch Kit? The AC Delco Part number for the 11" kit is 381258. It has an all steel throwout bearing. The National Sintered Pilot Bushing part number is PB-656-HD.
              NCRS New England Chapter Chairman 2022, 2024
              N E Regional Chairman 2024
              1967 Corvette Convertible Under Restoration
              1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
                • 43258
                [ATTACH=CONFIG]100338[/ATTACH]
                [ATTACH=CONFIG]100339[/ATTACH]
                Thomas-------
                This is not an OEM clutch. It's an ACDelco aftermarket clutch. I believe it's either a LUK or Sachs clutch in an ACDelco box. However, it's equivalent to the LUK clutch I previously mentioned and can be used without reservation.
                • Kevin B.
                  Infrequent User
                  • January 1, 1986
                  • 7
                  Gentlemen- Just asking- I'm pretty sure my L36 (427/390) has an 11" disc, (168 tooth flywheel) clutch. The aforementioned Luk kit 04-021 I think is 10.5" disc. Is there another part number? Or am I confused?
                    • 43258
                    Kevin-------
                    All 1966-74 Corvette big block used an 11" clutch except L-88, MA-6, and LS-6.
                    I erred above in saying that the correct LUK clutch is an 04-021. I hope no one purchased a clutch for an 11" application based on my error. The correct LUK clutch is an 04-049
                    • Bob W.
                      • December 1, 1977
                      • 802
                      Joe, I have a 1969 350/ 300 hp car would that have a10.5 or 11 in clutch.
                      Thanks Bob
                        • 43258
                        Thanks Bob
                        Bob------
                        I can guarantee you it has an 11" clutch because I am the original owner of an original 1969 350/300.
                        Actually, all 1969-81 Corvette small blocks except 1970-72 ZR-1 used an 11" clutch.
                        • Bob W.
                          • December 1, 1977
                          • 802
                          Joe. Thanks for the quick reply. we can always count on you for the correct answer. What color is your 1969 ?
                          Thanks Bob
                          • Mark E.
                            • April 1, 1993
                            • 4603
                            Kevin-------
                            What's MA-6?
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                              • 43258
                              Thanks Bob
                              Riverside Gold
