67 Ignition Switch - NCRS Discussion Boards
67 Ignition Switch
  • Ralph P.
    • February 1, 1990
    • 253
    67 Ignition Switch
    Anyone had experience rebuilding or cleaning an original ignition switch? Couldn't find any reference in the archives...
    THANKS
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: 67 Ignition Switch
    Ralph, I've repaired a few C1 ignition switches. C2 switches are very similar. Take a look at post 1 and post 5 in this thread. It shows how I was able to open them and clean the internals.
    Your 1967(1116686) switch has similar tabs to get inside. Online photos I found below. You have to carefully bend the 3 housing tabs to remove the backplate/contact base. I use a small drift and flathead driver to tap them outward. If the rivets holding the terminals are loose I'd suggest cleaning the rivet/terminal joint and soldering them.
    Best to test the switch after repair and before bending tabs back in. You can use a small C-clamp to hold it together for testing. A meter with alligator clips makes it easier. Also easier to set the key tumbler back in the switch to test.
    Here's how it should test....
    START:
    BAT = SOL = IGN1
    RUN:
    BAT = IGN1 = ACC
    ACC:
    BAT = ACC
    GND: Unused
    Rich
    • Ralph P.
      • February 1, 1990
      • 253
      Thank you, Rich ! Great information .... Anyone else done this on a C2 ?
      • Brian T.
        • September 30, 1990
        • 190
        Many, many, many times. Some are very much in need of service, and others look like they were hardly ever used.
