GM 1111247 67 427/400 Distributor Parts ID Help - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    All
    I have a 67 427/400 with a 1111247 single point distributor. I'd like to confirm the stamped numbers on the key parts such as centrifugal weights, cam, and shaft are correct for a stock configuration. Spring part numbers would be helpful as well. I believe the cam should be stamped with CCW 732 and the mainshaft should be stamped 171 but I'm not sure. I've not been able to find a listing anywhere. Any help would be appreciated.
    thanks
    Dereck
  • Mark F.
    • July 31, 1998
    • 1510
    Re: GM 1111247 67 427/400 Distributor Parts ID Help
    Contact Dave Fiedler at TI Specialty.
    Although he specializes in Transistor Ignition, he should probably be able to help
    T.I. Specialty is pleased to provide information pertaining to Corvette ignition systems. We are experts in our field and want to help you with your vehicle.
    thx,
    Mark
    • Arne A.
      Infrequent User
      • January 4, 2011
      • 10
      • Dereck S.
        • July 30, 2008
        • 244
        Thanks for the response. Very helpful. You'd have to pull it apart to see the shaft p/n. You've confirm everything else on my 247 distributor.
        thanks
        Dereck
