Distributor Caps - NCRS Discussion Boards
Distributor Caps
  • Michael M.
    • February 1, 1993
    • 604
    Distributor Caps
    From my research, 1968 - early 1969 used a cap that the top said " Delco-Remy Patent Pending 2769047. Is this correct and if so did the #2769047 have a " R " after the number?
  • Dave S.
    • August 31, 1992
    • 2926
    Re: Distributor Caps
    Michael,
    To my knowledge 047 caps ( with or without an R ) were never used on a Corvette before 1972 or possibly later. I know them as a later service distributor cap.
    • Michael M.
      • February 1, 1993
      • 604
      Dave, so a early build ( Oct. 1968 ) would require a D-308R which reads Delco-Remy Patent Pending "R". Is this a correct statement?
      • Dave S.
        • August 31, 1992
        • 2926
        I don't have the 69/69 TIM&JG with me but as I recall early 68's may have no "R" with PATENT PENDING. Sometime in 68 the R appeared as I recall.
        • Dick W.
          • 10483
          Michael,
          Bill Clupper told me years ago that caps were manufactured well into the '70's without the patent number.
          Dick Whittington
          • Michael M.
            • February 1, 1993
            • 604
            Thank you Dave and Dick. Does anyone have a 1969 judging manual to verify that all 1969 distributor caps say Delco-Remy Patent Pending R ?
            • Jeffrey S.
              • May 31, 1988
              • 1890
              The 5th edition guide says: "Delco-Remy and Patent Pending R are embossed on top of cap. Very early 1968 caps may have non-R caps."
              Jeff
              • Dick W.
                • 10483
                Interest tidbit of useless knowledge.
                Look at the patent number history
                Dick Whittington
                • Jeffrey S.
                  • May 31, 1988
                  • 1890
                  [ATTACH=CONFIG]100245[/ATTACH]
                  Also, the application was for the entire distributor not just the cap. I'm guessing that the cap was just a good place to post the "Patent Pending", etc. (?).
                  Jeff
                  • Dick W.
                    • 10483
                    Jeff
                    If the patent was for the whole distributor, I wonder why they waited as late as 1953 for file for the patent. They were making that same basic style in the '30's.
                    Dick Whittington
                    • Jeffrey S.
                      • May 31, 1988
                      • 1890
                      Dick,
                      I have a copy of the patent application dated Dec. 23, 1953 and it is for a "DISTRIBUTOR STRUCTURE". The text starts off with: "This invention relates to a distributor and is particularly concerned with an improved distributor wherein the operating elements thereof are inverted in order to accomplish improved operation within the distributor." The text further speaks to other improvements including access to the points adjustment through a window, cap attachment, improved vacuum control apparatus., etc.
                      Jeff
                      • Dick W.
                        • 10483
                        Dick,
                        Jeff
                        AHA, the window in the cap and the screw attachment are probably the main changes.
                        Dick Whittington
                        • Michael M.
                          • February 1, 1993
                          • 604
                          So, if my car was built in October of 1968 and has a distributor with part #1111493 what should the top of the cap say. "Delco-Remy Patent Pending" or "Delco-Remy Patent Pending R" ?
                          • Gary B.
                            • July 31, 1979
                            • 926
                            We see very few original unrestored very early 68's to use for reference. An October of 1968 built car, to me, is a very early 68. Others may say it's an early car, especially if it's the end of October build. That's 2-1/2 months of production.
                            68-69 6th Edition TIM&JG says "Very early 1968's may have a cap without the R." We don't know how late they were used. Left over 1967 parts. You will find the 68-69 Judges very knowledgeable and will probably not make a deduction for a cap without a R.
                            You would be safe to use either for judging. If you want to play it really safe, just use a R caps. Either way, it's your decision.
                            Gary Bosselman
                              • 11659
                              I'll be the one to say it....
                              Isn't an October 1968 car from the 1969 model year?
                              I am suspecting that Michael's car was built in October of 1967, which as Gary infers would make it an early 1968.
                              PH
