1967 need to replace the high beam bulb - NCRS Discussion Boards
  • Terry H.
    Infrequent User
    • February 21, 2007
    • 15
    Problem: after removing the two screws on the sides of the bucket, the bulb frame is still binding at the bottom. The top is loose, how do I free the bottom? Thank you
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 1967 need to replace the high beam bulb
    Aren't there 4 screws - two more on the bottom ?
    My 63 has four..in each bucket. A 67 may be different...
    • Tom E.
      • June 1, 2019
      • 448
      Terry,
      there are 4 screws that hold the bezel in place. 2 on the side and 2 on the bottom.
      Tom
      • Leif A.
        • August 31, 1997
        • 3626
        Originally posted by Tom England (65936)
        Terry,
        Tom
        Agree with Tom and Frankie. Those screws are different. Side screws are different than the bottom screws. Don't get them mixed up...threads are completely different.
        Leif
        • Frank D.
          • December 27, 2007
          • 2703
          And you'll want to take extra car reinstalling those side screws - they have small heads and need to be fully tightened so as not scrape a groove on the sides of the bucket cavities as the buckets rotate.... May want to "blip" that dashboard bucket rollover switch to get the screws close to the body, then stop, and double-check the clearance...
