Trailing arms going in....this is a May 63 car with the press fit bearings and I want to be positively sure I do this right (and once)!
The 63 docs have specs referring to the original slip fit design (or so I've read) so I'd rather get some advice here..not sure the press fit makes a difference on half-shaft torque but want to be certain.
Half-shaft to differential U-joint (straps) torque: 20 ft/lbs (and blue Loktite); I'm aware getting a torque wrench in there is nearly impossible but is this info correct..?
Half-shaft to trailing arm flange: 70 ft/lbs (and blue Loktite)...and can I get away with the original French locks not twisting if I lube the bolt heads.. Otherwise I'll order stainless steel versions.
Finally - are the (attached) pictured French locks correct for May 63 ? What I have are the later curved versions I suspect ?
Thanks in advance !
Thanks in advance !
