body on - NCRS Discussion Boards
body on
  • Mel S.
    • August 31, 1992
    • 264
    body on
    I have done all the work on the body and frame on my 66 convertible. Now is the time to put the body back on the frame. i have my body on the the lift in my garage and the tires on dollies so the frame is very movable. My thought was to use a "plumb bob" and line up the body mount holes with the ones on the frame. Then lower the body down SLOWLY, adjust as needed and insert the bolts with the mounts, shims and washers. Any input would be greatly appreciated.
    Mel
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: body on
    Purchase some long bolts, 4-6", that fit in the body mount nuts. Cut the heads off and install the bolts in 2 holes to be used as "pilot" guides as you lower the body. I installed the guides in the rear locations....worked like a champ.
    • David H.
      • June 30, 2001
      • 1559
      Re: body on
      Originally posted by Mel La Scola (21474)
      I have done all the work on the body and frame on my 66 convertible. ...
      Mel
      Carpet and door sill trim pieces installed?
      If not, then body/frame alignment pins can help. (Birdcage sill holes & frame thru holes line up)
      Dave
      • Jim D.
        • 2885
        Re: body on
        Mel
        I've done several doing exactly that and never had an issue.
        • Richard G.
          • July 31, 1984
          • 1718
          Re: body on
          The rubber fender seals installed?
          Watch the shift lever as it can break easily.
          Post some pictures if you are so inclined.
          Best of luck.
          Rick
          • Tom E.
            • June 1, 2019
            • 448
            Re: body on
            Mel
            • Mel S.
              • August 31, 1992
              • 264
              Re: body on
              Thanks to all for the support. I will have 5-6 guys in my garage when we do it. I purchased the wheel dolly's in the late 90's at Hershey and finally have a reason to use them. They really make it nice to mover the chaise around. Mel
              • Mark P.
                • May 13, 2008
                • 951
                Re: body on
                Mel - it is good to have someone making sure the shifter is clearing the shifter hole when you lower it. I had a bungee cord holding it in the lower left position which helped alot. Mark
                • Mel S.
                  • August 31, 1992
                  • 264
                  Re: body on
                  Thanks but i put a Tremech 5 speed in
                  Mel
