Holley Fuel Inlet Washer Question - NCRS Discussion Boards
  • Al P.
    • February 15, 2011
    • 87
    Haven't had the Vette out for about a month or so, so I get it all shined up and ready to go.
    Idling on the driveway warming the BB up and I smell gas.
    I lift the hood and fuel is dripping like a faucet on the second fuel block on my tri-powered 435.
    It was leaking from the middle Holley Carb fuel bowl inlet.
    I tried to tighten the bowl inlet fitting which had a white nylon washer with the line fitting loose;. I was getting a soft tightness feel, so I did not want to strip the bowl.inlet threads.
    Removed the bowl inlet fitting , threads look perfect as does the bowl threads as well.
    The white nylon washer is very brittle.
    I can thread the inlet without the washer all the way in securely so this confirms the threads are good in the bowl.
    So my question is:
    What is the recommended washer used with the Holley bowl inlet fitting (the one that screws directly into the Bowl?
    Ive seen a very thin Holley fuel inlet washer made of steel , thin and flat, or the thicker White nylon one that I had?
    What do you guys recommend and how tight do I tightness the bowl inlet fitting and line fitting? And whee can I purchase the correct bowl washer?
    Thank You All
  • Joe R.
    • July 31, 1976
    • 4551
    Re: Holley Fuel Inllet Washer Question
    Al,
    Here's a pic of a filter kit from Holley. It has two of the gaskets you need.
    I would not use the white nylon gaskets on a bet. By the time they get tight they are distorted and leak!!!!
    Probably get those filter kits from Jegs.
    • Chris H.
      • April 1, 2000
      • 837
      • Al P.
        • February 15, 2011
        • 87
        Try 3/8ths copper flare gaskets and that should do the trick.
        Where do i get these? and are these conical seals or?
        Thanks for the response!
        • Al P.
          • February 15, 2011
          • 87
          Thanks Joe,
          What are these washers for the inlet made out of?
          • Chris H.
            • April 1, 2000
            • 837
            Al, I get mine from the local Grangier or Amazon.
