54 corvette Powerglide rear pump - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Is number on pump 3713660 GM12 correct for the 54 corvette. also is there a cost for excellent used and or new? Thank you. Brad.
    • 43222
    Re: 54 corvette Powerglide rear pump
    Brad-------
    I doubt this part number is the part number for the pump assembly. More likely, it's the casting number for some component of the pump and likely the pump body. In any event, the part number for the 1955-56 rear pump assembly for V-8 applications was GM #3713661. So, I suspect that the 3713660 was a component of that pump.
    • Brad H.
      • August 12, 2007
      • 724
      Thank you Joe for the info. Brad.
