Ballast resistor - NCRS Discussion Boards
Ballast resistor
  • Wayne B.
    Infrequent User
    • December 13, 2017
    • 2
    Ballast resistor
    I recently noticed that the ballast resistor on my 67 ( 327/300hp ) is getting very hot after only a couple of minutes. Never noticed this before. Normal? If not, anyone have an idea why? Thanks, Wayne Billyer NCRS member # 64240
  • Jim D.
    • 2883
    Re: Ballast resistor
    Perfectly normal.
    • Wayne B.
      Infrequent User
      • December 13, 2017
      • 2
      Thank you, Jim,
      • Larry M.
        • January 1, 1992
        • 2688
        Agree with Jim............but non-original coil could also contribute to excess heating.
        Larry
          • 15663
          That's why it's mounted in a ceramic block. They get hot, but most never notice unless they inadvertently touch the wire. You can measure resistance, which should be about 1.8 Ohms at room temperature. The OE coil is a ...202, and the primary resistance is listed in the CSM. You can also check the voltage drop across each at idle speed.
          The wire material is formulated to increase resistance with increasing temperature to protect the coil and points from excessive current. The late Dale Pearman (MIT engineering grad) used to refer to it as an "analog computer"... a crude one for sure, but he was right!
