53-55 6V Radio & Lighter Wiring - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    It would make sense for the radio dial lamp to be able to be dimmed by the light switch rheostat along with the other instrument panel lights. However, in the three very low mileage unrestored cars I've documented the brown radio light wire is attached to the back of the light switch and thus cannot be dimmed. Those three cars include a mid 53, early 54 and late 54 so this appears to be a common trend in the wiring over two years. This photo is an example of the three cars and is from a 3040 mile late 54.
    The most vintage wiring diagram does not show the radio, heater, cigarette lighter or E-brake warning. Those were all considered options or accessories back in the day. So that left restorers guessing unless they made good notes on how they were wired before disassembly.
    Eventually (around 2004) someone created a color wiring diagram that included all of those except the E-brake warning. In that version some of the wire colors for those options are incorrect. It shows the radio lamp and cigarette lighter lamp connecting to some unknown location that eventually connects to the front lug on the light switch controlled by the rheostat. I suspect ever since then restorers have been connecting the panel lights, radio light and cigarette lighter wires to the rheostat. But is that how the factory did it?? The photographic evidence I have shows otherwise. Still more data is desirable before a conclusion is made.
    I know the PV manual calls for checking for dimming of the radio lamp. But there is always a possibility that came from the logic that it should have been able to be dimmed and reinforced by the late color wiring diagram.
    So my question is do any of you have photos or other wiring information that would show us how the radio lamp was actually wired to the light switch by the factory? The cigarette lighter lamp is also of interest.
  • Troy P.
    • February 1, 1989
    • 1284
    Re: 53-55 6V Radio & Lighter Wiring
    I have a theory that the radio was installed after the light switch was already wired and installed. The easiest place to put the radio lamp brown wire without removing the switch was one of the two available lugs on the back. In other words the easy way out was taken. To get to the lug controlled by the dimmer rheostat the switch would have to be removed.
    • Jim L.
      • September 30, 1979
      • 1817
      I tried to make a picture of the radio light wiring in #3300. The attempt was awkward because of how and where my '54 is in my shop. So, I just stuck the camera up under the dash and pressed the shutter. What I got is ambiguous but I don't think the radio light wire attaches to the headlamp switch at all.
      Tomorrow, I'll move things around and try again.
      Jim
      • Troy P.
        • February 1, 1989
        • 1284
        There are two wires from the radio. One has a fuse at the end and goes to the accessory junction panel. That provides power. The other is the radio lamp wire that goes to the light switch. Will be interesting to learn what you find.
