An embarrassing question - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    I hate to even post this but I am stumped.
    When I put the OHM meter on my C6 spark plug wires I can see the resistance and calculate if they are good or bad.
    I have a set of 4 Q 62 wire on my 63. When I perform the same test I get no results. It's as if the wire has a break, but the car runs. Saying that, I have a 6 inch piece from the same 100 foot spool of unused wire. Same reaction, no resistance.
    How does one bench test these?
    What am I missing?
  • Mark E.
    • April 1, 1993
    • 4607
    Re: An embarrassing question
    "has a break" is different than "no resistance".
    Are you measuring infinite resistance or zero resistance?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • David H.
      • June 30, 2001
      • 1558
      Harry
      Carbon core or wire core?
      Dave
      • Harry S.
        • July 31, 2002
        • 5344
        Originally posted by David Houlihan (36425)
        Harry
        Dave
        Carbon core, this is 58 year old NOS Delco wire
        • Joe R.
          • July 31, 1976
          • 4552
          Harry,
          When Carbon Core is broken and has little or no resistance it can still work well cause the spark will jump the break! Just like it does on the spark plug! It will eventually burn a hole in the insulation and quit working!
          JR
          • Larry M.
            • January 1, 1992
            • 2701
            Agree..............carbon core wire does not last forever. Typically 10-20 years was its service life.
            Time for new wires.
            Larry
            • Harry S.
              • July 31, 2002
              • 5344
              Let me ask the question again. These are new wires made from NOS 4 Q 62 wire. How are they tested. They have not been installed yet.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17929
                Harry,
                Do you have a good digital VOM? IIRC carbon wires resistance can run anywhere from 4k ohm to 12k ohm resistance. The better the wires the lower the resistance.
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Larry M.
                  • January 1, 1992
                  • 2701
                  Things like carbon core wires can deteriorate on the shelf. Test as Gary says, and if you used a good meter and got very very high resistance or an open circuit, you have your answer.
                  Larry
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    Personally, if that style wire is that old, I'd think twice about installing them...but its not my car.
                    • Harry S.
                      • July 31, 2002
                      • 5344
                      Before I bought the 100 ft spool I did a good deal of research. Essentially the conclusion was that the carbon wire will last forever. After installed and put in service many things can go wrong. Scrapes, pinching, burns, etc.
                      I built two sets, one set is in my 300hp coupe and the other was in the 250hp convertible. The coupe has been running great for years. I shot the parts cannon at the convertible to fix a problem. I installed the Summit wires there. I'm just trying to test them to see if they failed. I'm trying to compare the resistance against a third set I just built.
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        "Parts cannon" - Nice!
                        I just did a spark plug and wire install on my 250hp week before last, snaking the wires through the motor mounts and looms and wrestling with the shielding - a PITA. Would have been brutal without a lift... To wit, if you can make 100% certain the wires will be good when done then I guess its OK...
                        • Harry S.
                          • July 31, 2002
                          • 5344
                          I got that from you... I like it also!
                          • Joe R.
                            • March 1, 2002
                            • 1356
                            Hi Harry:
                            Tell us more about the ohm meter you are using. A hand-held ohm meter applies, at most, a few volts to measure resistance. It is possible that the resistance measured with a few volts is higher than the resistance measured with 30,000 volts from the coil.
                            Another factor is when the ohm meter has selectable ranges rather than auto-range. If the meter range is set to 10K ohms, any resistance larger than 10K ohms will read as "infinite."
                            If the ohm meter range is set to meg-ohms (millions of ohms) and it still measures "infinite," it is possible that the carbon-composition cable has a tiny open circuit that won't break down at 5 volts but will break down at 30,000 volts. However, I think that a carbon-composition cable that behaves this way is in the process of failing open, even at 30,000 volts. I believe that healthy carbon-composition wires measure at a few hundred ohms per foot when tested using an ordinary ohm meter.
