65 396 survey? - NCRS Discussion Boards
65 396 survey?
  • Dan A.
    • May 31, 1974
    • 1074
    #91
    Re: 65 396 survey?
    Originally posted by Mike McCagh (14)
    i just added our three 65 L84's to rob's list. mike
    Mike all three VIN's 194675S109302, 164375S105094, 194375S108472 are listed as new.
    194675S109302 and 194375S108472 are listed as Mike McCagh owner. 164375S105094 is listed as owner unknown.
    All three cars are listed as 250hp.
    All are listed as other color for exterior and interior and no options.
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 988
      #92
      Re: 65 396 survey?
      Bill Williamson had a pretty extensive survey, but I'm not sure what happened to his work after he passed away. Steve Walker may know.
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
        • May 31, 1974
        • 8391
        #93
        Re: 65 396 survey?
        don't know how i screwed up registering our three 65 FI corvettes. the registry has them listed as 250 HP. I distinctly remember checking the L84 box when i registered earlier today. will have rob look into the mis-information. thanks for the heads up dan. mike
        • Gary C.
          • April 1, 1998
          • 376
          #94
          Re: 65 396 survey?
          Is there anymore information on #15822?
          • Tom D.
            • September 30, 1981
            • 2134
            #95
            Re: 65 396 survey?
            Sorry, I have nothing on 15822.
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Andy C.
              1963-4 Team Leader
              • April 1, 1998
              • 119
              #96
              Re: 65 396 survey?
              Gary,
              Here are some 396 Engines and Vins These are not on your list. I have no Info on what the cars were5119689 IF.jpg5122823IF.jpg
              • Mike E.
                • February 28, 1975
                • 5139
                #97
                Re: 65 396 survey?
                Circling back to the post that started this: The Nassau blue convertible with blue/white interior is #17224. St. Louis body S5588. 900FF paint. J10 trim tag. Owner says trim is 45186. Not sure of the accuracy on the trim data--school me on this if you will. Most original underhood components are long gone.
                • Dan A.
                  • May 31, 1974
                  • 1074
                  #98
                  Re: 65 396 survey?
                  Trim 451B? represents white/bright blue leather seat interior in a convertible . The 86 you were quoted should be two lettters. The first letter should be B for convertible. A for coupe. The owner needs to take a second look. We both know a picture is worth a thousands words. Paint FF is Nassau Blue. All St Louis bodies have the 900 prefix. Body build date J10= May 10th. You have access to this stuff don't you Mike?
                  • Mike E.
                    • February 28, 1975
                    • 5139
                    #99
                    Re: 65 396 survey?
                    I do. Was just adding this to the data file, and knew the trim data (45186) was incorrect.
                    • Joe M.
                      • February 1, 2005
                      • 590
                      Re: 65 396 survey?
                      Here is a pic of a 65 ragtop from circa 1971/72. I bought it for parts. no engine trans or rear. Reason I think it is a BB is the rear sway bar, heavy front sway bar and accelerator rod and arm. Trim tag and Vin tag were removed. Title has a Z after the vin, no clue if that is a state iissued designation or vette.
                      Perhaps someone can confirm or deny it as a BB from this old pic. pic of date stamp from lower edge of right frnt fender. Front fender emblem holes were glassed over but the back side clearly shows three holes in a triangle pattern. holes look factory and unmolested.
                      Joe
                      • Dan A.
                        • May 31, 1974
                        • 1074
                        Re: 65 396 survey?
                        The photo showing the firewall lacks the detail to see the location of battery cable clips which could be indicators.
                        • Gary C.
                          • April 1, 1998
                          • 376
                          Re: 65 396 survey?
                          We now have 300 L78's on the list;
                          1965 L78 Corvettes July 31 2020.xlsx
