66 427 Engine Install - NCRS Discussion Boards
  • Michael H.
    • December 1, 1987
    • 733
    Helping a friend install a 427 engine in a 66, it's been to long ago I can't remember can you install the engine and transmission as an assembly into the car with the body on ? We plan on leaving the exhaust manifolds, water pump and distributor off the engine.
  • Tom K.
    • February 26, 2008
    • 167
    • Michael H.
      • December 1, 1987
      • 733
      Re: 66 427 Engine Install
      Thanks Tom, How is your car coming along ?
      Mike
      • Owen L.
        • September 30, 1991
        • 891
        Originally posted by Tom Kreyling (48649)
        Mike, I don’t think it is a problem. The car has to be up as high as possible as you can on jack stands and you need to use an adjustable angle top connection to the hoist. That should give you enough clearance to slowly angle the assembly into place.
        Tom
        In addition to this advice, I've heard that having the rear of the car raised higher than the front allows some more angling room for the trans to get into position.
        • Michael H.
          • December 1, 1987
          • 733
          Thank you Owen.
          • Paul S.
            • June 30, 1982
            • 359
            You can do it ( i just did) ,we had 3 guys (extra hands help ) a little swearing and we got her in as an assembly !
            • Michael H.
              • December 1, 1987
              • 733
              Thank you Paul,
              Did you have the radiator installed ? How about the exhaust manifolds ?
              Mike
