On disassembly my late '63 had the Spring Cushion Retainers 'crimped' into the leaf spring and swing arm bolt holes. I would like to duplicate the crimps on assembly. I have obtained a set of retainers from Long Island Corvette that fit the spring and swing arm with minimal clearance. The first set I purchased had an outside diameter at least 1/8" smaller than the diameter of the outside spring bolt hole.
Is there a tool or a process to properly crimp these cushion retainers to the leaf spring and swing arm??
Thanks Joe
Thanks Joe
