Question on the 1965/1966 BBC Oil Pan(Center Bolt) - NCRS Discussion Boards
  • Larry E.
    • 1692
    Just want to verify what is in the 5th Edition of the 66 Corvette judging guide. It says that the 66 Big Block
    engines had the center bolt in the the Oil Pan and Timing Cover. Is this correct? Also was this the only years
    this happened? Seems like a good idea. Maybe Joe Lucia can shed some light on this. Any idea's if the current crate engines have this feature? Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Keith B.
    • September 15, 2014
    • 1591
    Re: Question on the 1965/1966 BBC Oil Pan(Center Bolt)
    65- 66 BB only. I think its the same 1/4-20 bolt used on the oil pan rails
      • 43255
      Larry------
      The only big block engines that used the center bolt from oil pan to the timing cover were the 1965-66. It's possible that very early 1967's may have also used it IF any were originally built using engines with 3869942 blocks. The change to blocks with dowel pin locating provisions for the timing cover obviated the need for the bolt, at least in the mind of GM engineers.
      No crate engines built in the last 50+ years have had provisions for the bolt. In addition, no timing covers sold in the last 50 years have had the hole and weld-nut for the bolt. The hole also disappeared from oil pans about 50 years ago but, of course, can easily be added.
      The bolt used was GM #3856691, the same as used for the corner bolts for the oil pan. This was a 1/4-20 X 5/8" bolt with captured split lockwasher and phosphate finish.
      • Leif A.
        • August 31, 1997
        • 3646
        Larry------
        Joe,
        Out of curiosity, is this the timing chain cover you are talking about?
        Leif
          • 43255
          Originally posted by Leif Anderson (29632)
          Joe,
          https://www.parts123.com/parts123/yb...Z5Z5Z50000370a
          Leif-------
          This is the 67+ cover. It has dowel pin holes and does not have provisions for the center bolt. The 65-66 cover has no dowel pin holes and does have the hole and weld nut for the center bolt.
          • Leif A.
            • August 31, 1997
            • 3646
            Leif-------
            Thank you Joe
            Leif
