1967 roadster carpet - NCRS Discussion Boards
  • Tom E.
    • June 1, 2019
    • 448
    Trying to finish up the carpet install on my 67 convertible. Can someone post photos of the left and right rear corners where the seat belts attach and the quarter trim panels meet. The AIM is only so much help and all the photos I found on the forum are for a coupe. They may be the same but I want to make sure I get it right.
    Thanks Tom
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: 1967 roadster carpet
    Tom, This post should help....
    https://www.forums.ncrs.org/showthre...475#post731475
    Below is a 1967 convertible, driver side.There should be a hole in the fiberglass panel for the screw to secure the carpet flap. If the new carpet won't reach the original screw hole you may need to drill a new hole.
    This photo shows the screw, however not the correct type.
    • Tom E.
      • June 1, 2019
      • 448
