C2 Dial back timing light - NCRS Discussion Boards
  • Richard S.
    • April 1, 2003
    • 288
    I am looking for a dial back timing light to use on my 63 340 HP car. My past experience has been with standard light and timing tape. But I see advantage in the newer approach. Problem is when I go out to look on line I am not sure if the timing lights I see are a dial back or just a standard light with some features. A check at local auto stores brings blank stares. Any help appreciated.
    Rich
  • Mike M.
    • May 31, 1974
    • 8399
    Re: C2 Dial back timing light
    snap-on dial back timing lites are frequently on ebay. i got a used one for under 50 bucks last year. they are nearly indestructible. mike
    • Frank D.
      • December 27, 2007
      • 2703
      An Actron CP7529 is what I've used for years, pretty much bulletproof if you keep the wires off hot manifolds, etc.. Available reasonably nearly anywhere. Less than $50 on Amazon
      • Dick W.
        • 10483
        Unless you let the leads make contact with hot headers
        Dick Whittington
        • Edward D.
          • October 25, 2014
          • 206
          I use an Innova Professional digital timing light. In addition to digital dial back, it gives you RPM, dwell, and voltage on the readout.
          • Jim D.
            • 2884
            I use that one as well. It works great with conventional ignition systems but not with multi-spark systems. For those, I break out my 45 year old Sears/Penske light.
            • Richard S.
              • April 1, 2003
              • 288
              Thanks Frank for the information. Looks like a good choice. Since my wife has Amazon prime the shipment is free.
              Rich
              • Richard S.
                • April 1, 2003
                • 288
                Thanks Mike number of choices. Not sure of one over the other. I will probably just flip of coin.
                Thanks Rich
                • Richard S.
                  • April 1, 2003
                  • 288
                  Ed many thanks for all the detail on your timing light. To bad I am unable to see the number of choices presented in operation. But I will pick one.
                  Rich
                  • Mark E.
                    • April 1, 1993
                    • 4597
                    I haven't received it yet, but I also chose the Innova 5568. It's a digital tool that's a generation beyond a dial back light...Instead of turning a knob, it displays RPM vs. advance real time with an LCD display. It's the only light I found that also measures both dwell and volts.
                    A little over $100.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      A little over $100.
                      If I needed to replace my Actron (which I don't) then this is the one I would go for I think...
                      • Leif A.
                        • August 31, 1997
                        • 3642
                        Another vote for the Innova. Does everything as advertised. Very easy to use.
                        Leif
                        • Richard S.
                          • April 1, 2003
                          • 288
                          Thanks Mark
                          I did see your comment and had not thought about a newer design. I plan to order something early next week so you gave me something else to consider before I make my choice.
                          Thanks again
                          Rich
                          • Richard S.
                            • April 1, 2003
                            • 288
                            To all that commented on the dial back timing light Innova 5568. I did return the defective light and received new light. The new light works fine.
                            Rich
                            • Patrick B.
                              • August 31, 1985
                              • 2002
                              My Innova 3568 quit working today. The dial back feature quit working and the LCD screen became intermittent, but the timing light continued to flash at 0 degrees. I have had it about four years with a total of about 1 hour of use. I really liked this thing, but I don’t want to reward the company by buying another. Can anyone suggest a more durable alternative?
                              I have Sears Penske timing lights that are 50 years old and still work. It is annoying to have this thing fail with little use but too long after purchase to complain to Amazon.
