How to install rivets for C3 battery hold down hardware? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4536
    How are the rivets installed that fasten the battery hold down hardware? For reference, the photo below is a hardware kit from Paragon which includes the five rivets.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • 6941
    Re: How to install rivets for C3 battery hold down hardware?
    Mark, I would try to make something up, all you should need is some round stock maybe 7/16ths,and a piece flat thick metal, maybe something in the tool box?? Take the round stock and cup the middle to look like the factory install. It would help to a have a extra hand to hold the flat metal while you use a small hammer to set rivet.should not take much the soft rivets will set easy. Good luck
    • Michael L.
      • December 15, 2006
      • 1390
      Edward is correct it can easily be made from a bar of steel and a proper sized drill bit to make a relief in the bar. It's definitely a two person job. Or you could get the tool that Paragon sells:
      https://www.paragoncorvette.com/p-35...-tool-316.aspx
      Mike
      • Mark E.
        • April 1, 1993
        • 4536
        Thanks Edward and Mike! Very helpful.
        Paragon seems a bit proud of their tool.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
          • 11643
          There is a machinist who is at the larger meets (BG, Carlisle) who sells tools to do this. They work well, and are much less $ than the Paragon one.
          • Michael L.
            • December 15, 2006
            • 1390
            No problem. I got the kit from Eckler's a few years ago but the one that I got had a number of different tools to do rivets of various sizes and it had a thick heavy bar of metal to hold the head of the rivet in place while you set it, but you definitely don't need that, a heavy hammer will work fine. Here is the kit I got:
            I also got the tool I posted earlier which I used with my air chisel to impact the rivets down but this is probably overkill as Ed mentioned. The Eckler's kit and a hammer will allow you to set these rivets. They're very soft and easy to crush.
            Mike
            • Tom L.
              • October 17, 2006
              • 1439
              I've got one of these for the same job for the rear battery hold down. Ordered the wrong rivets so I'm waiting until I order something to get the correct ones. Hate to pay more shipping than the part is worth. If you want to borrow the tool let me know. Probably won't need it for a while.
              • Mark E.
                • April 1, 1993
                • 4536
                Tom- Thanks for the kind offer; I may take you up on it.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Mark E.
                  • April 1, 1993
                  • 4536
                  In the last post of this thread, Dick Gutman suggests getting a used pneumatic aircraft rivet gun:
                  https://www.forums.ncrs.org/showthre...How-to-Install
                  I have a pneumatic air hammer. Will that work with the right head installed?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Mark E.
                    • April 1, 1993
                    • 4536
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Tom L.
                      • October 17, 2006
                      • 1439
                      I would think that an air hammer with an assistant using a "Buck" was how it was done at the factory. Manual labor is expensive.
                      • Michael L.
                        • December 15, 2006
                        • 1390
                        Yes Mark, as I mentioned I used the air hammer/chisel to set my rivets. It's quite easy to do. The attachment from paragon that I posted above is made to fit in these tools to crush the rivets down. A heavy hammer or other object held on the other side of the rivet by an assistant is needed to do this.
                        • Mark E.
                          • April 1, 1993
                          • 4536
                          I'm a bit slow on the uptake. Until now I thought the Paragon tool was used with a regular hammer.
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
