I mounted 5 new Coker 6.70x15 Firestone tires on new repo 15x5.5 wheels. When I tried to put the spare in the fiberglass tub on my '63 it would not fit. Coker advertises that these tires are made in the original molds. So one is lead to believe they are the correct diameter.
Now I found the inside diameter of the tub measures 28" and the drop down tray is only 25". Coker's specs say the diameter of the tires they sold me is 28.58". So now its obvious why they don't fit.
How have others successfully dealt with this problem? Is there a reproduced thin whitewall 6.70x15 that does fit?
Looks like I can't use a tub stretcher because the sides of the tub are already against the mufflers.
