Oil filter canister - NCRS Discussion Boards
Oil filter canister
  • Dana B.
    • November 1, 1998
    • 147
    Oil filter canister
    I checked the archives ,didn't see oil filter container details .. Oil change on a '57 ... when do I change seals O rings, snap rings ,other seals with in the oil filter canister after a 40k rebuild and 30 years and best place to get the parts ?? . I think it
    's due !
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Oil filter canister
    There is a gent that restores them (others will have his name) including new silk-screened label, but otherwise I don't know why you'd mess with it - there is not much in there short of a shaft, spring and cartridge retainer with a copper washer on the bottom under the bolt head, both my 61 and 63 ran the original canisters for decades... The vendors sell "rebuild" kits but I'm not a fan of them...
    • Jimmy G.
      • November 1, 1979
      • 976
      If it is not broke -- Dont fix it If it does not leak, use it as it is. If looks are the question, Richard Fortier does them Not cheap but very NICE
      • William F.
        • June 9, 2009
        • 1363
        Main thing is when you remove cannister and old filter for filter change, you must you a pick to remove the old gasket up in the recess where the cannister goes. Then install a new gasket which will come with the new filter . If you overlook removing the old gasket you'll get a big leak. don't ask me how I know.
        • Mark S.
          • July 31, 1983
          • 659
          I have a friend that did not remove the old gasket; and he ended up freezing his engine up.
          • Jim L.
            • September 30, 1979
            • 1808
            How? Why?
            Expiring minds want to know.....
            • Frank D.
              • December 27, 2007
              • 2703
              I use a strong flashlight and dental pick to make SURE the old gasket is removed and after I snug up the canister I run a super thin bondo spreader around the periphery of the canister at the block to make SURE I didn't tighten the canister against the block and not fully into its recess..
              • Mark S.
                • July 31, 1983
                • 659
                Jim:
                I am also in that expiring mind phase of life. What happened, is that my friend's son-in-law did not take the old gasket out and put the new gasket in on top of it. The two gaskets produced a gap where the oil ran out; and he did not notice it until the engine froze up. This last winter provided an expensive rebuild on the engine. I am surprised that he is still in good relations with his son-in-law. He probably wishes he would have changed the filter himself.
                Mark
                Mark
                • Jim L.
                  • 1808
                  Jim:
                  Mark
                  Copy that. Thanks for the explanation.
                  FWIW (likely not much), I can't remember the last time I went to the trouble of pulling out the O-ring gasket when changing the filter on the engine of my '60. It wasn't leaking before the change and it won't get better if I replace the gasket, so I've left it alone thru several oil changes. I bet that O-ring is at least 20 years old.
                  Jim
                  • Larry M.
                    • January 1, 1992
                    • 2688
                    Many folks have run with two gaskets around the filter can without issues. My car was the same when I purchased it. Obviously not a good idea to do this, but oil failure is not always the result.
                    As others, I use a dental pick to remove the old o-ring gasket, wipe the cavity clean with a soft cloth, lube the new o-ring with Vaseline and put it in the cavity. The Vaseline (or a light grease) will hold the gasket in place. Install the filter can and filter, and then torque to spec.
                    Never an issue in 25 years with the car.
                    FWIW: The reproduction filter cans are thinner and provide less sealing surface. I used one for awhile, but found an original and had it restored. I feel more confident with the original can.
                    Larry
                    • Jim D.
                      • 2884
                      Larry
                      That's how I've done it 100's of times for 50 years and never had an issue.
                      • Wayne L.
                        • September 30, 1981
                        • 233
                        When I do want to change the o-ring, I just remove the two capscrews that hold the check valve up to the block, remove the valve and o-ring.
                        I have also had issues with the reproduction canisters (wall thinkness too thin). I use the restored original cans from Richard Fortier-very nice. And, the silk screen is in the correct location.
                        Wayne
                        • Dana B.
                          • November 1, 1998
                          • 147
                          Thanks all for the comments . When I removed the can last week , I found the internal snap ring was not in the groove on the bolt . It had slid up the bolt to the bolt threads .This is what triggered my original post . I plan to replace the snap ring . Should there be a rubber washer between the top of the spring and the cone ? This PF 131 didn't have one. ( I believe later PF 141 had it) Will I be ok to reuse external copper bolt washer ? Dana
                          • William F.
                            • June 9, 2009
                            • 1363
                            May be talking about 2 different gaskets? The gasket that goes in groove where cannister contacts it that you need to change when you change filters is not an "O" ring, but a circular gasket that is flat on its mating surfaces. You can get away with not changing it or running 2 gaskets by accident for a while but definitely not a good idea.
                            • Frank D.
                              • December 27, 2007
                              • 2703
                              I wouldn't bet an engine on that.... I have personal knowledge of a '61 that dumped several quarts of oil on the highway because of that very mistake. Only a lightning quick shutdown saved the motor...
