Help with Pertronix install - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 618
    Re: Help with Pertronix install
    With the distributor mounting on the engine, some of installation steps are difficult due to the tight area. Easy to drop screws, etc. I had installed the Pertronix unit on my 327 and it ran fine. However, I always worried that if I got stuck on the side of the road due to a failure in that unit, it would be a real pain to go back points after the install - again to do so on the road. When I had my distributor re-built I did not use the Pertronix unit, but instead went back to points. Very easy to recover from that setup. It’s a risk reward thing and given how infrequently most of these cars are driven combined with no real performance enhancement, I stuck with points. Just an opinion as I am sure there will be others that will swear by the Pertronixs.
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • Leif A.
      • August 31, 1997
      • 3645
      If one is dead set on swapping the old points for an electronic substitute, a much easier install is the Breakerless SE system. No additional wiring, uses the standard ballast resistor and, once installed, there is no way to tell you have anything non-stock installed.
      Leif
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        #18
        Thomas,
        I carried a spare distributor for 5 years after installing the Petronix. Drove that '64 for over 20 years with the Petronix ignition without any problems.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • William F.
          • June 9, 2009
          • 1364
          #19
          Hank, Can you do "dial back" timing check with this timing light?
