Engine won't crank - NCRS Discussion Boards
Engine won't crank
  • Michael L.
    • December 15, 2006
    • 1416
    Engine won't crank
    Guys,
    Looking to start my 69 350 4spd corvette today for the first time in nearly 30 years after a lengthy restoration. I have the coil wire disconnected while I work out the kinks. When I push in the clutch and turn the key it doesn't crank over. It cranks just fine with my remote trigger that I connected to the starter. Pretty sure the neutral safety only needs the clutch pushed in, correct? Not sure what else I could be missing. Appreciate your thoughts.
    Mike
  • Michael L.
    • December 15, 2006
    • 1416
    Re: Engine won't crank
    Figured it out. Neutral safety switch got knocked loose with all my messing around under the dash in the 8-9 months since I connected it. Duh.
