65 Hubcaps Paint - NCRS Discussion Boards
65 Hubcaps Paint
  • John F.
    • March 23, 2008
    • 2421
    65 Hubcaps Paint
    I am trying to refurbish a set of 65 driver hubcaps. Are the slots and outer indented ring painted satin black?
  • Don H.
    • December 1, 1981
    • 1496
    Re: 65 Hubcaps Paint
    It is more of a gray color, Long Island sells it.
    • John F.
      • March 23, 2008
      • 2421
      Do you have a picture of yours? I don't recall seeing gray.. Would it be flat, satin, gloss?
      • John F.
        • March 23, 2008
        • 2421
        This was a satin black. I made my own mask. inside & outside picture.
        • Don H.
          • December 1, 1981
          • 1496
          The JRM calls it "roughly textured medium gray."
          • Jim D.
            • 2885
            Yup. Here's a pic. of an untouched original.
            • John F.
              • March 23, 2008
              • 2421
              Thank you guys!
              • Donald H.
                • November 2, 2009
                • 2589
                I restored my 66 hubcaps, which I believe is the same paint as 65. Pictured below left to right is an untouched original before restoration, and the next two are my restorations and the LIC paint. The paint is a little darker than the original, but I'm not sure if some of that could be due to fading of the original paint over time.
                The originals have a textured finish and you do not get that with just normal spraying the paint. What I did was carefully mask everything except what was to get painted. I rolled the edge of the tape so that I got a soft and not crisp paint edge (like the original). Then I laid the hubcaps flat and shot the paint from a distance, but only misting then let that dry a little then misted again. I think they turned out very good and close to the original texture.
                Don
                Don Harris
                Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                • John F.
                  • March 23, 2008
                  • 2421
                  Thanks for the info Don. Since mine is just a driver set, I am going to leave alone with the satin black. It almost looks gray!
                  • James W.
                    • December 1, 1990
                    • 2673
                    VHT Cast Blast Gray spray paint works great also.
                    James
                    • John F.
                      • March 23, 2008
                      • 2421
                      While I was doing this yesterday, I found one cap was missing the backing plate as shown in the attached photo. Anyone have an extra laying around.
                      • Wes S.
                        • May 31, 1982
                        • 209
                        Here's an NOS on straight out of the box
