What would cause the tach needle in my '67 coupe (base engine) to 'stick' at a given RPM?
For example, when I start the car it accurately shows the idle RPM. Sometimes when I accelerate the car the tach needle may act normally and rise and fall with engine speed. But sometimes the needle will 'stick' at a given RPM and not follow engine speed as it should. If I turn the engine off the needle will momentarily stay 'stuck' before dropping back to zero. At other times if the needle is stuck at a given RPM i can 'unstick' it by revving the engine beyond the 'stuck' RPM. The needle will then move up to read the proper RPM and act normally, at least for a while.
I had the distributor rebuilt with a new tach gear a couple of years ago after the old tach drive gear galled up. I also removed the tach cable to lubricate it when I installed the rebuilt dizzy. Soon after the tach started acting erratically and while checking things I noticed that I had inserted the tach cable backwards. So, I put it back in the correct way but the sticky behavior has continued on and off since then. I read somewhere that the tach end of the cable has a circular (brass?) thingy around it to stop lube from migrating into the tachometer instrument. So, is it possible that some crud got into my tach head and gummed up the works?
Is there anything I can do to free up the tach needle at this stage?
Thanks for your advice on this 'sticky; subject!
