who to sleeve a master cylinder? - NCRS Discussion Boards
  • Mark G.
    • January 31, 2007
    • 177
    Is White Post Restorations still the go to place for sleeving a master cylinder?
  • Dick W.
    • 10483
    Re: who to sleeve a master cylinder?
    They used to be the only place. And still do good work. You will not be sorry
    Dick Whittington
    • Tony R.
      • April 19, 2017
      • 201
      White post did a nice job on mine.
        • 43221
        Dick-----
        Doesn't White Post only do brass sleeving?
        • Peter H.
          • April 1, 1980
          • 225
          I Believe Richard Fortier From MICHIGAN Still Sleeves Master Cylinders . He Does The Extra Step Of Staking The Sleeve . Peter
          • Harry S.
            • July 31, 2002
            • 5302
            Try ---->https://brakeandequipment.com/ They have done two 63 MC for me as well as some wheel cylinders. I'm happy with results and price.
            • Mark G.
              • January 31, 2007
              • 177
              Thanks for all the replies.
              • Dick W.
                • 10483
                Dick-----
                As far as I know Joe they still do. I know of some of their work that is going on 40 years old with no problems. Brass ain't a gonna wear out in a M/C or wheel cylinder.
                Dick Whittington
                  • 43221
                  Dick------
                  I agree. I was not implying that brass was inferior.
                  As far as material goes, even cast iron would not be a wear problem, at all. It's that water that gets into the system that causes the problems. If the cars had silicone fluid from the beginning there probably wouldn't be a sleeved caliper or master cylinder out there.
                  • Dick W.
                    • 10483
                    Dick------
                    If they had silicone in them in humid areas H2O would still be a problem. Silicone, as you know is not hydroscopic, but moisture still gets in the system. It forms little pockets that may gather in the M/C, lines or calipers and basically never move, creating corrosion in limited, but still problematic areas. I believe it is the reason the military, who BTW uses silicone in all their hydraulic brake systems, flush the braking systems annually to prevent this from happening.
                    Dick Whittington
                      • 15601
                      If they had silicone in them in humid areas H2O would still be a problem. Silicon, as you know is not hydroscopic, but moisture still gets in the system. It forms little pockets that may gather in the M/C, lines or calipers and basically never move, creating corrosion in limited, but still problematic areas. I believe it is the reason the military, who BTW uses silicone in all their hydraulic brake systems, flush the braking systems annually to prevent this from happening.
                      Dick,
                      How does moisture get into the system if the fluid is not hygroscopic? Hydroscopic is not the word you want -- look it up.
                      • Edward B.
                        • January 1, 1988
                        • 537
                        I'm sure White Post can do acceptable work, but on two separate occasions I sent them a complete set of four wheel cylinders to be sleeved. On each occasion I had to return at least one cylinder to be reworked. I have since switched to Apple Hydraulics and have had zero problems. http://www.applehydraulics.com/
                        • Bill C.
                          • May 31, 1989
                          • 424
                          I have used Apple hydraulics many times, never a problem, quick turn around, very reasonable.
                          • Larry M.
                            • January 1, 1992
                            • 2694
                            Lone Star Caliper and Brake in Texas is another quality source for this work.
                            Larry
                            • Gary B.
                              • February 1, 1997
                              • 7023
                              Thus last week Richard Fortier told me he is no longer able to resleeve brake master cylinders. The guy who did the resleeving for Richard is no longer able to do that work and he was the only person Richard used.
                              Gary
