Re: M 305 date code on 1975 333882 cylinder head
Terry, The Restorer story you refer to, as I recall was; "M for Mystery" by
I had a 1972 with a M code block and although it is unusual, no one seems to care and trying to explain what it is makes a conventional dated casting better to own.
https://www.forums.ncrs.org/showthread.php?50906-M-code-block&highlight=mcode%20saginaw&uid=4876
Apparently the numbers have nothing to do with a date.
Gene Gamache
. The NCRS link to that story does not work.I had a 1972 with a M code block and although it is unusual, no one seems to care and trying to explain what it is makes a conventional dated casting better to own.
""M"-Coded Blocks: There is one exception to the normal block casting date convention that has been observed: some blocks have been seen with "M" cast codes. Research by the Saginaw Metal Casting Operations of GM Powertrain Division has found that these "M" codes are not date codes, but actually a foundry code used to indentify parts that were made to evaluate a casting process change. After evaluating the parts, the blocks would either be destroyed or released into production. There is no way to determine the date an "M"-coded block was poured."
