Quick help needed on 63 rear brakes - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    Not sure they were together right in the first place but two quick questions on the RIGHT REAR factory drum brake parking brake "spreader" and spring...
    1) is the spreader oriented correctly (curved outboard and the right end forward), and,
    2) Is the spring oriented correctly - with the extended prong pointed forward and upward
    Thanks in advance!
  • Michael S.
    • August 11, 2019
    • 135
    Re: Quick help needed on 63 rear brakes
    frank here is a pic of the left rear brake on my 63. hope it helps. mikeIMG_0948.jpg
    • James W.
      • December 1, 1990
      • 2673
      Here's a pictureof a right rear brake assembly.
      James
        • 6956
        Frank, Springs face forward and outward on both sides.
        • Harry S.
          • July 31, 2002
          • 5344
          The loop on the spring goes over the tit, pointed out in blue..
          • Frank D.
            • December 27, 2007
            • 2703
            is item "D" the correct orientation - with concave side inboard ??
            If so I have mine flipped ... ugh !
            NEVER MIND - they'll only go one way !
            • Harry S.
              • July 31, 2002
              • 5344
              Wait for more pictures, I think you are ok. I just did a wheel cylinder last week and already deleted the pictures.
              • Frank D.
                • December 27, 2007
                • 2703
                I think I've got it now, have to back to NAPA one of the brand new Dorman wheel cylinders leaked and made a mess and a bunch of rework.
                Grrrr...
                • Frank D.
                  • December 27, 2007
                  • 2703
                  All done - thanks Harry/James/Michael/Edward; I have the original 63 wheel cylinders on the shelf and I'm gonna rebuild 'em and quit dealing with the aftermarket stuff I think...
                  • Frederick H.
                    • August 31, 1983
                    • 480
                    Been there, done that. After-market stuff stinks.
