Where does this vin tag go on a 69? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1413
    Guys?
    I'm getting ready to re-rivet my data tag to the door pillar so I went to get it out of the envelope I had it in and this other tag was also in there (see pic). I believe the body shop guys removed it when they removed the data plate. Can anyone tell me where it goes? I searched the forum and my JG but couldn't find anything. Thanks for your help.
    Mike
  • Mark M.
    • October 21, 2008
    • 342
    Re: Where does this vin tag go on a 69?
    69 vin tag is riveted on left windshield post looking from outside the car down above the dash. There should be two holes there and the interior molding has a coped area that goes around the tag. The rosette rivets are easiest to install with windshield out.
    • David H.
      • June 30, 2001
      • 1559
      Michael
      See Mark's reply for location. Tag located under windshield to make removal difficult. Federal law classifies removal of a VIN tag as a felony.
      Dave
      • Michael L.
        • December 15, 2006
        • 1413
        Unfortunately the holes are now filled on the door pillar. Guess the body guys screwed that one up. Is there anywhere where the exact location of this plate is supposed to be? Maybe the AIM? Also, my windshield is in already so nothing I can do about that. Is there anywhere I can get these rosette rivets you mentioned? I don't see them in my vendor catalog. I also don't see the rivets for the data tag. Are they available?
        • Owen L.
          • September 30, 1991
          • 891
          (Not my car or pic) You can see that the pillar trim has a cut-out area for the VIN tag. As I recall on my '72 it's about 1/3 of the way up from the lower corner of the windshield. That should get you in the right area at least.
            • 43273
            Michael-------
            I don't know of any way to install the VIN tag with the proper rivets with the windshield already installed.
              • 11692
              Michael-------
              Agreed. I think that if he wants to be legal, that windshield is coming out...
              • Mark E.
                • April 1, 1993
                • 4607
                Why was the tag removed? Damaged or rusty windshield frame?
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Michael L.
                  • December 15, 2006
                  • 1413
                  • Mark M.
                    • October 21, 2008
                    • 342
                    Mike, nos black rosette rivets are on ebay. If the car is checked before the tag is put back where it came from, you may have a can of worms to deal with. I would not drive it with that small part missing.
                    • Michael L.
                      • December 15, 2006
                      • 1413
                      Thanks for the heads up. I'll get that done asap. I ordered the black rosette rivets. As I recall the data plate was installed with only regular round rivets. I've searched ebay for those but don't see any. Are they just standard rivets?
                        • 43273
                        Michael------
                        If by "data plate" you are referring to the trim tag. that was attached with more-or-less ordinary pop rivets.
                          • 43273
                          Michael-------
                          Pictured below are NOS GM #9127909 rivets [not for sale]. These are the rivets originally used in PRODUCTION for the 1969 trim tag (NOT the VIN tag).
                          The rivet head is 1/4" OD. The rivet barrel is 1/8" OD. The barrel length is 23/64".
