re-Dye/paint interior or not? - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Looking for some thoughts on this. Finally finished my carpet and I'm cleaning up the interior parts prior to installing them. the black isn't real sharp, almost dull. Is it advisable to paint or just let it ride. just concerned about flaking and the such down the road.
  • Edward D.
    • October 25, 2014
    • 206
    Re: re-Dye/paint interrior or not?
    I assume you are talking about the black plastic trim parts. On those try a plastic surface conditioner/treatment conditioner like Mothers Back To Black. Don't paint unless its an originally painted part in which case SEM Trim Black works well. The spray "dye" all the corvette suppliers sell is actually a soft paint. This stuff can easily chip and peel if surface prep isn't perfect.
    • Mark E.
      • April 1, 1993
      • 4552
      Have you tried a protectant product, like one from 303 or Meguiar's? If the finish isn't failing (peeling, flaking) it's worth a try. These products can improve a dull look.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Tom L.
        • October 17, 2006
        • 1439
        Talking mostly about the vinyl covered pieces. And no have not tried any protectants. Just noticed how dirty and dull all of it was when I took it out into the daylight. I cleaned it today and it wasn't much better. I've done a few plastic parts and they look great, just not sure about the vinyl. Thanks!
        • Mark E.
          • April 1, 1993
          • 4552
          Tom,
          If the vinyl is not cracked or torn then definitely clean and treat it. Much of the dullness may actually be dirt build up that's hard to detect because of the black color.
          For cleaning, a lot of detailers use dish soap diluted with warm water in a spray bottle. Use a soft brush to gently work it in. Old vinyl cracks easily so don't press much- be gentle.
          Works great but may take several applications.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Tom L.
            • October 17, 2006
            • 1439
            I used SEM soap to clean the vinyl, a big improvement but the color just didn't pop. I'll try some protectant and see. Thanks!
            • Don L.
              • August 31, 2005
              • 1005
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Tom L.
                • October 17, 2006
                • 1439
                Hi Don, I'm thinking the protectant will be OK. I never noticed how dirty all the behind the seat trim was until it saw daylight. Either you didn't notice when you saw the car at Carlisle OR you were polite and didn't say anything. I'm real bad about pics. Thought about taking them but didn't. I'll post some after pics if my brain remembers.
                • Tom D.
                  • September 30, 1981
                  • 2134
                  Let us know which protectant, if you do that. Thanks.
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
