Bare frame with front suspension installed - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7065
    My next project is to put the front suspension onto my bare chassis. When I do that, of course the A-arms will be will be forced to their most downward position by the coil springs. I think the only thing stopping the upper A-arm from hitting the frame is the single, pointed, rubber bumper that inserts into the top of the fame. If my A-arms stay in that position for, say, 6 months, is that rubber bumper going to be destroyed by being compressed from the force of the coil spring?
    Gary
  • Tom E.
    • June 1, 2019
    • 448
    Re: Bare frame with front suspension installed
    Gary,
    My frame stayed that way for probably 4 months with no issues. You could leave them out and install later but you would need to either compress the springs or devise a method of jacking the LCA up while keeping the frame from moving with it.
    Tom
    • Jim S.
      • March 13, 2013
      • 360
      Gary
      I can't see how that would destroy the rubber bumper. Plenty of cars have been on jack stands for 6 months at a time
      • Paul D.
        • September 30, 1996
        • 491
        I wouldn't worry about the bumpers. Remember to leave bushing retainer bolts loose until after final assembly when car should be closer to normal ride height. When I built my 71 the first time before I knew better, I let a frame shop rebuild the front end when car was just a body on the frame. Within a couple years after getting it on the road, all the bushings were twisted and cracking. Chip.
        • Gary B.
          • February 1, 1997
          • 7065
          Paul,
          Yup. I started with the rear suspension and rear cross members and I already have a list of which bolts are final torqued and which ones a just more than finger light.
          Gary
