Loose shifter - NCRS Discussion Boards
Loose shifter
  • John R.
    • May 5, 2020
    • 12
    Loose shifter
    I am new to corvettes and recently picked up a 71 LT1. The shifter is loose when in neutral, but a bit everywhere. Is this common and can it be fixed? Just looking at how involved it would be. THanks.
    • 11653
    Re: Loose shifter
    Most of the catalog vendors sell rebuild kits to help tighten up the shifter. They work quite well, and aren't hard to install.
    • John R.
      • May 5, 2020
      • 12
      Re: Loose shifter
      Thanks - so more a full rebuild than bushings?
      • Mike E.
        • February 28, 1975
        • 5139
        • John R.
          • May 5, 2020
          • 12
          Re: Loose shifter
          OK, thanks. This will be a good winter project.
            • 43242
            Re: Loose shifter
            John------
            Check the "blade" on the very bottom of the shifter lever. If there is wear on this blade, as is common, you'll never have a properly operating shifter. In that case, your best bet is to obtain a complete new shifter assembly. Many years ago I tried rebuilding a shifter which suffered from the kind of wear I described. I used all new GM parts to rebuild it. When I was done I had a shifter which did not perform properly. I ended up just buying a new GM shifter assembly which were then still available. Current reproductions are good.
            • John R.
              • May 5, 2020
              • 12
              Re: Loose shifter
              Thanks Joe. That seems to be inline with the other recommendations. Looks like a project for me this winter. It's not horrible, just not to my liking. John
