No engine check light - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5338
    I figured I'd ask since C6's are soon to be judged. Started the C6, 2006 base engine after the winter. I know it's been hot but I live in NH. Anyway, missing and ran like crap. Felt like a coil but no check light. I put in my FIXD and ran it with the phone attached. It picked up a P0301 code. ( Cylinder 1 misfire ). I replace the coil, plug wire and plug on cylinder 1 and the problem is gone.
    Anyone else not getting engine codes/lights on the C6 on the dash?
  • Brian M.
    • February 1, 1997
    • 1841
    Re: No engine check light
    The Icon lights when you turn the key?
    • Harry S.
      • July 31, 2002
      • 5338
      Brian, nothing on. Looks normal.
      • Joe R.
        • July 31, 1976
        • 4552
        Good for you Harry! Go back to sleep!
        JR
        • Mark L.
          • 561
          Harry, I had a problem with my 09 with misfire. Actually Ed Johnson found the problem which was a bad ignition wire. Hard to believe with only 22000 miles.
          • Mark E.
            • April 1, 1993
            • 4606
            I think Brian is asking if the check engine light illuminates with the engine on but not running, or while cranking. That's a test the light works.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Harry S.
              • July 31, 2002
              • 5338
              Yes, all is normal on startup, all the icons illuminate.
              The local dealership, a mechanic friend, said there needs to be a certain amount of misfires within a revolution to turn the light on.
              • Mark L.
                • 561
                That makes sense as I did not see a check engine light.
