67 Roaster windshield Fastener Asm - NCRS Discussion Boards
  • Tom E.
    • June 1, 2019
    • 448
    Item 5, fastener assembly #3830287 UPC1 Sheet F22 shows these as the windshield side outer molding upper corner clip. They are actually a screw and spacer in the AIM and actual photo below. Cam someone post a photo of this item installed? I have looked all around my windshield frame and can find no place for the threaded screw to fit.
    thanks Tom
  • Gary D.
    • August 31, 1985
    • 52
    Re: 67 Roaster windshield Fastener Asm
    I think that screws to the clip on the top windshield trim piece. there should be several and the go in hole in widshield frame and screws into tthe retainer clip on the top trim. Gary
    • Tom E.
      • June 1, 2019
      • 448
      Thanks Gary, a picture is worth a thousand words... I have yet to find a threaded hole on the frame or a moulding. All the holes are for Sheetmetal screw threads, not machine threads.
      • Tom E.
        • June 1, 2019
        • 448
        Ok, I’ve figured it out. Goes inside the window frame and attaches To the the upper moulding clips in the left and right corners. Seems simple once you see it.
