head lights - NCRS Discussion Boards
head lights
  • Bruce W.
    • June 30, 1997
    • 360
    head lights
    Hey Guys, Can someone tell me a good source for NOS head lights for a 65 vette? Thanks
    Bruce
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: head lights
    Good used bulbs are sometimes a lot better than NOS NOS units have a tendacy to "smoke" quickly versus tried and proven originals.
    • Keith B.
      • September 15, 2014
      • 1604
      Re: head lights
      just buy the newer LL repro bulbs and call it a day
      • Richard G.
        • July 31, 1984
        • 1718
        Re: head lights
        I have a set of both the originals and the LL repops.
        The bad;
        They do have some differences and can be identified as reproductions.
        The good;
        They claim the Reproductions take a few more watts and are brighter.
        Originals T3 high beams are easy enough to find for a decent price. Low beams are expensive.
        Rick
        • Keith B.
          • 1604
          Re: head lights
          The bad;
          The good;
          Rick
          take your chance with originals and loose 25 in ops for one not working or lose four points in exterior for repro
          • Harry S.
            • July 31, 2002
            • 5349
            Re: head lights
            Keith, actually the math is a bit different. You have 4 headlight, two high beam and two hi-low. That's 6 bulb functions. 25/6 = 4 points per function failure. So, if just one high beam is out, that's a 4 point hit.
            • Alan D.
              • January 1, 2005
              • 2054
              Re: head lights
              Bruce,
              These are considered a Standard Deduction covered in the Corvette Judging Reference Manual, available on this site.
              Here is the headlight section. Now I assume you are concerned with judging, for the road use other stuff at the best price.
              • Frank D.
                • December 27, 2007
                • 2703
                Re: head lights
                I have a set of 4 originals with 2 spare high beams....only good for judging; the OP doesn't state his intentions....
                If you have a good set and slather some hi-temp RTV around the electrodes they may actually get through judging without a blowout.
                If its for driving, plug in a good set of Halogens so you can actually see at night...
