Full time vacuum 69 427/400 - NCRS Discussion Boards
  • Grahame M.
    • November 7, 2011
    • 225
    Hi Everyone,
    I know this has been asked and answered many time in this forum after reviewing many posts on the subject. I just can't seem to find any posts with clear pictures or diagrams of where the 3x2 carb vac hoses go and in particular the cut in for full vacuum?
    Any help would be much appreciated and if anyone can link me to a thread for this information i'd be forever grateful.
    Many thanks
    Grahame
    69 427 Tri-Power 4 Speed
    Black on Black
    • 43219
    Re: Full time vacuum 69 427/400
    Originally posted by Grahame McCann (54038)
    Hi Everyone,
    Many thanks
    Grahame
    Grahame------
    You can tee into the line that goes to the choke unloader on the center carb.
    • Grahame M.
      • November 7, 2011
      • 225
      Joe,
      Thanks for the quick response, can this also be called the choke pull-off?
      Black on Black
        • 15669
        Yes... also called choke vacuum break. Take off the existing hose and save. Buy a couple of feet of 1/8" tubing and a tee, and build a new harness.
        I don't know the VAC specs for your engine, but make sure it passes the Two-Inch Rule, idling in neutral if a manual trans and Drive if an automatic If not buy a VAC that does.
        After completing the change go through the idle speed/mixture adjustment procedure, and you will also need to reset the fast idle speed to spec.
        • Jeffrey S.
          • May 31, 1988
          • 1882
          If the smog equipment is there, couldn't you also "T" of of that vacuum line?
          Jeff
          • Grahame M.
            • November 7, 2011
            • 225
            Thanks Duke,
            i have all your (and others ) articles and threads saved on this subject so hopefully will complete this update soon. I have an original refurbed clutch and 7 blade fan, new water pump, hoses and a Dewitts direct fit aluminium radiator and new seals, so i'm hoping this will fix overheating problem. From the threads i have it seems like it will.
            Once i get it back running i'll recheck vacuum (was at between15-16", CR around 180 all cylinders) prior to garaging. The only issue i had in this area was the vac gauge needle fluctuated back and forth slightly but this is probably a question for another day.
            Thank you again for everyones comments, very much appreciated as always.
            Cheers
            Grahame
            Black on Black
              • 43219
              Jeff
              Jeff------
              I believe the vacuum source for the diverter valve is ported vacuum.
                • 15669
                The diverter valve should be full time vacuum, but it takes about 20" Hg to open it. The valve's purpose is to divert injected air through the muffler to the atmosphere when the throttle is lifted to avoid exhaust afterfire.
