1975 hood stuck closed passenger side - NCRS Discussion Boards
  • David H.
    • June 30, 2001
    • 1544
    Re: 1975 hood stuck closed passenger side
    Bob,
    Several threads available with google search. One below:
    Dave
    • Bob B.
      • January 31, 2007
      • 524
      Reading now thanks
      • Dan B.
        • July 13, 2011
        • 545
        #18
        With the hood fully closed, if you push down on the stuck side, can you get any downward movement? There should be some clearance there. Try pushing down first, then pulling the latch cable real hard before trying to open it. Maybe the latch is not able to fully open due to interference with the pin.
        Your hood gaps are still good and you did not change any of the latching hardware, or mess with the stops before putting the hood back on right?
        • Bob B.
          • January 31, 2007
          • 524
          #19
          Gaps very good, going to remove driver assy to get a better angle to pull cable harder. Will push hood to check up / down movement
          Anybody have a chain saw ??? FREE BEER for helper
          Bob
