63 rear drum brakes - NCRS Discussion Boards
63 rear drum brakes
  • Frank D.
    • December 27, 2007
    • 2703
    63 rear drum brakes
    Doing my annual inspection of the original drum setup and the fronts checked out fine, the rear - not so much. Memory isn't so hot but I don't recall seeing a shoe crack like this (PS rear wheel trailing shoe). Just crappy off-shore materials maybe ?
    The drums look fine and don't even appear to need "dressed up"..no "checking", no scorched/glazed spots, nada...plenty of "meat" still on them.
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: 63 rear drum brakes
    Frank,
    I would look for a NOS GM set and in the near future put them on, It probably won't hurt to leave it until you find a set. The size was probably used on quite a few models of the era.
    Do you recall where the existing parts are from?
    PS, did your wife throw you out of the garage again...
    • Frank D.
      • December 27, 2007
      • 2703
      IIRC the brakes on the car are generic NAPA brakes I put on in 2016 before judging...and I would assume the shoes would have self-arced by now... I don't know of any outfit the "old school" arcs drum brakes any longer.
        • 15678
        I wouldn't be too concerned about it, but if you detect any kind of problem with the rear brakes do another inspection. I've had semi-metallic disk pads loose chunks or material from race track hot lapping, but it had no discernible impact of performance, and I ran the pads to the usual 4/32" thickness before I replaced them. If only street driven I would let them wear to 2/32s, but the less material the hotter the brake fluid gets, so if tracking a car my replacement criterion is different.
        The crack might be thermal related, but I didn't think you ever drove the car very hard. One thing that might be worth doing is taking a something like a dental curette and beveling the edges of the crack down to solid material to remove any loose flakes that might be pulled off in the future.
        • Frank D.
          • December 27, 2007
          • 2703
          Those are not Harbor Freight jack stands in the picture!
          And I always have a floor jack or sometimes two (under pressure) in a critical spot (as shown) even when using quality jack stands...even when I'm not sojourning under the car...
