Specs on "special washers" noted in AIM - NCRS Discussion Boards
  • John M.
    • April 18, 2017
    • 184
    When looking at the 66 AIM part numbers 3765135 (special washer) and3706737 (washer L 79 only) are noted as being used for mounting the air conditioning compressor. Does anyone have the specs on these two washers? Need both but have no idea what to look for. Thanks!
    • January 31, 1988
    • 43191
    Re: Specs on "special washers" noted in AIM
    John------
    Nothing really too special about them:
    GM #3765135----13/32" ID, 11/16" OD, 3/32" thickness, zinc plated; discontinued without supersession 2011
    GM #3706737----13/32" ID, 3/4" OD, 3/16" thickness, zinc plated; discontinued without supersession July, 1998
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11298
      gmpartswiki has some specs....
      A=ID, B=OD, C=Thickness
      3765135 Also this Page states "Plain".
      3706737 Didn't find finish on this one. (Joe did as I was looking)
      • John M.
        • April 18, 2017
        • 184
        Anyone have a source for a washer 3/16"" thick" ?
        • David B.
          • February 29, 1980
          • 686
          3706737 is in '66 P & A under GRP. 7.371 It is listed for '53 Corvette. I can understand how you could miss that one!
          • David L.
            • July 31, 1980
            • 3310
            I googled the parts numbers on the web and Dr. Rebuild sells the 3765135 GM washer for $4.50 each and the 3706737 GM washer for $10 each........a real bargain!
            Dave
            • John M.
              • April 18, 2017
              • 184
              Is anyone aware of a 5/16 flat washer 3/4 inch in diameter and 3/16" thick that a person can buy? Dr. Rebuild seems to be closed for now. Any suggestions would be appreciated!
              • Dick W.
                • 10483
                Dick Whittington
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11298
                  Just found this at Grainger..... Main Page Here
                  1/4" 5/8" 3/16" Case Hardened N/A
                  Regular Price$9.90 / pkg. of 10
                  5/16" 3/4" 3/16" Case Hardened N/A
                  Regular Price$10.50 / pkg. of 10
                  Compare
                  GRAINGER APPROVED
                  Grainger Choice Product
                  5/16"x3/4" O.D., Extra Thick Flat Washer, Steel, Case Hardened, Black Oxide, PK10
                  • Item # 5RY26
                  • Mfr. Model # Z9201
                  • Catalog Page # 2090
                  View Product Details
                  Web Price
                  $10.50 / pkg. of 10
                  Expected to arrive Thu. May 14.
                  Ship To 33301
                  Qty
                  • John M.
                    • April 18, 2017
                    • 184
                    Thanks to all of you for the help! Ordered 10 of the73250094 thick washers from Grainger as well as some of the thinner (but still thicker than hardware store variety) 71925879 washers and promised delivery date is this Thursday. If anyone reading this needs any of those numbers contact me through this board and they are yours for a SASE. Again, thanks for all of the help. Some of these little details are very time consuming and it is help from all of the members of this forum that allows an individual to find a solution.
                    • Jim S.
                      • February 28, 1986
                      • 1392
                      Thread: 67 L-79 a/c compressor bracket spacer
                      It appears Long Island Corvette has what you need . 34-31 (4Xs)
