which firewall hole does the front indicator harness pass through on a 69? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1395
    Guys,
    I'm routing the front indicator harness on my 69 coupe and trying to figure out which hole the harness goes through. I have the disassembly pics that clearly shows that this harness passed through the hole just to the right (as seen from the engine bay) of the steering assembly (see attached pics). This car was a very original car when I disassembled it and I can't see how it could have been altered from assembly. In the second picture the harness is going through that hole after the restoration. The problem is, the grommet for the harness is too small for this hole. It simply passes right through the hole. The grommet seems to be for the hole just under the fuse box (seen in the second pic) but that's not where my disassembly pic tells me the harness went through when I took it apart. Can anyone shed some light on this?
    Mike
    Pre-disassembly:
    Current:
  • Michael L.
    • December 15, 2006
    • 1395
    Re: which firewall hole does the front indicator harness pass through on a 69?
    Just recycling this to see if anyone can help.
